STM32CubeMX Code Generation for STM32CubeIDE without linking library files
2020-03-04 10:56 PM
why it's not possible to copy all neccessary library files to my generated project for CubeIDE?
When I choose EWARM, then this is possible...
Thanks a lot,
Ben
STM32CubeIDE
STM32CubeMX
2020-03-04 11:05 PM
Hello @Community member ,
You need to Uncheck the "Generate Under Root" first then you will have access to all options.
Best Regards,
Khouloud
2020-03-04 11:05 PM
Best Regards,
Khouloud
2020-03-04 11:07 PM
Thanks, this works!
2020-03-04 11:08 PM
(Only the "Copy all used.." is grayed in your case, if you have a problem in other options thanks for telling me).
