2021-04-08 11:47 PM
I am trying to generate code using stm32cubeMX. During code generation pop-up appreasres and shows the following error.
Error downloading files:
stm32cube_fw_h7_v180.zip(cannot unzipped)
2021-04-09 12:43 AM
Hello @AFaya.1
Thanks for your post,
Could you please try with the latest version ? (CubeMX 6.2.1 and FW H7 1.9.0)
Khouloud
2021-04-09 2:58 AM
Actually i was created and working on STM32 cube IDE 1.5.1 integrate with cudeMX. If i update my IDE version 1.5.1 to 1.6.0 that produce error on make file.
Then how did i update cubeMX with out update STM32 cube IDE.
2021-04-09 3:03 AM
And another concern i have only 3GB free space in my disc. Is cubeMX take more than 3GB space?
2021-04-09 3:45 AM
Hi again @AFaya.1 ,
You can use the CubeMX standalone then generate your code on CubeIDE (normally its size is less than 3 GB) , or even better, you can uninstall you current IDE version then install the latest one (1.6.1) from site.
Tell me you still face an issue, I'll be waiting for your feedback :)
Thanks, Khouloud
