STM32CubeMX 6.2.1 Does not allow the setting dead time for HRTIM in push pull mode
- June 10, 2021
- 3 replies
- 2620 views
Hello ST community.
I am use NUCLEO-G474RE, wanted to set up HRTIM in push pull mode with dead time. I select the set and reset sources for outputs TA1 and TA2 period event and compare 1 event. But when i turn on dead time, TA2 setting is considered to be wrong.
If remove set sourse for TA2 and run program, i get incorrect pwm signals.
When i manually configure a set sourse for TA2 everything works fine.
I am attaching a project with a fixed bug.
