STM32CubeMX 4.14.0 bug report - gray comboboxes
petr239955
Posted on March 26, 2016 at 23:44
I tried a new version 4.0 of STM32CubeMX. I selected the STM32F746G-DISCO board.
If I set the Detect_SDIO GPIO: Input ad PC13, closed and openedthe ioc file,
then the comboboxes are gray and you can not change.
Petr
stm32cubemx gray-comboboxes
3 REPLIES 3
Nesrine M_O
Lead II
Posted on March 28, 2016 at 10:44
Hi Petr,
Thank you for your feedback. The issue has been reported internally.
-Syrine-
stm32cube-t
Senior III
Posted on March 29, 2016 at 18:19
Thank you for reporting this issue.
As a workaround, from the pinout view, click the corresponding pin and set it to reset. This reopens the platform settings for user configuration. Click the pin to reconfigure it as GPIO_input.
stm32cube-t
Senior III
Posted on October 06, 2016 at 17:32
Dear user,
The issue has been solved in STM32CubeMX release 4.15.
Best regards
