2024-09-11 6:35 AM
Hi, I'm facing a problem with the Clock Configuration tab with the latest version of the STM32CubeIDE. In fact, every time I open the ioc file, there is an error with the SMPS Clock Mux on the STM32WB board I'm using. I correct and generate code and saved but when I open the file again the error is still there. I'm using the latest version of the Cube.
Thanks.
2024-12-02 12:57 AM
@mƎALLEm wrote:
I reproduced the behavior.
I will escalate the issue internally and get back to you as soon as I have an answer/feedback.
Internal ticket 190817 for follow-up.
Issue fixed in CubeMx V6.13.0
2024-09-11 6:46 AM
What error is displayed? Could you please share your ioc file?
2024-09-11 6:50 AM - edited 2024-09-11 7:08 AM
2024-09-11 7:03 AM - edited 2024-09-11 7:16 AM
Thank you for your patience.
2024-12-02 12:57 AM
