2021-01-30 8:23 AM
I use STM32CubeIDE under MacOS. I don't understand whether it is a bug or not. I can not change Input frequency of HSE in clock configuration. I can do it in CubeMX under Window on the same project.
2021-02-04 1:15 AM
Thank you for your reply! This problem was fixed by itself by several restarts of the CubeIDE.
2021-02-04 12:54 AM
Hello @EL314
Can you please share your ioc file to check from my side?
Thanks, Khouloud
2021-02-04 1:15 AM
