STM32 CUBE IDE Bug This function (PeriphCommonClock_Config(); ) is not generated from the cube ide . is this normal in the new update or its a bug?
MSale.1
I use STM32H Series. H735 and H7A3
Imen.D
Hello @Community member​ ,
Please have a look at this post, and check if you have the same conditions as described by khouloud.
Otherwise, please provide more details on your use case to understand the issue.
Imen
Imen
Imen.D
Imen
Imen
Imen.D
​Hi @Community member​ ,
Please let me know if your issue is solved, if so please close this thread by marking "Select as Best" button.
Imen
Imen
