Question about debugging in sw4stm32
DCha.1
I use STM32F429ZI​ with dwm3000evb from decawave
I executed a example code in systemworkbench for stm32
But there is an error message
​info : unable to match requested speed 2000 khz, using 1800 khz
I​ don't know how to solve this error and I want to know what causes this error massage
Please help me​
It's just an informational message that can be safely ignored, not an error that needs solved.
The debugger attempted to connect with one speed, it didn't work, so it fell back on a slower speed. Auto corrected.
The root cause is buried in a configuration script somewhere.
If you are in a position to switch, STM32CubeIDE is far better than SW4STM32 which is abandoned.
