freddy
Incorrect path .elf file
  • April 10, 2025
  • 3 replies
  • 549 views
Recently I changed from Windows to Linux. Now I'm working on a older project and when debugging I got the message "program file does not exist" wit the details:
.../Projects/VxxT/VxxT_firmware/Debug\VxxT.elf not found
I've found that the problem is the backslash in the path and that this is an artifact of changing operating systems.
My question is how to correct this so the IDE looks for the right file?
Best answer by TDK
Change it in the Debug or Run Configuration tab.
Tesla DeLorean
Guru
April 10, 2025
The software engineer in me says write a small app or script..
Check other project files which are working, against those that fail, compare and contrast.
Do I think that ST should sanity check this, and fix it, yes sure, but it would annoy me to edit a project file more than once to fix it.
TDKBest answer
April 11, 2025
freddy
freddyAuthor
Thanks, that worked, the error is gone.
Pavel A.
April 11, 2025
Please review the project settings for the build artifact(s) and ensure that all slashes are / not  \, this will work even on Windows. Eclipse on Windows will take care to substitute these slashes, but it cannot always guess for the opposite direction. If you are brave, open .cproject and .launch files in a text editor and replace all backslashes there.
