2022-05-04 12:09 AM
HI,
I am working on STM32F413zh and i am trying to enable FSMC_NL gpio pin. I dont't know what is the purpose and how to enable this pin in STM32cubeMX. Please give me the support.
Thankyou.
2022-05-12 9:57 PM
I found it, thankyou for your reply. FSMC_NL for ALE purpose. While i was changed the configurations as per reference manual that was able to enable. Also working fine.
2022-05-04 1:54 AM
Why do you want to enable it if you don't know what is it's purpose?
It is used only for memories with multiplexed address/data buses, or in (quite rare) memories which require a latch signal for address.
What memory do you intend to connect to FSMC?
2022-05-12 9:57 PM
