OpenAMP issue on STM32H745
2025-04-16 7:14 AM - last edited on 2025-04-16 8:33 AM by mƎALLEm
Software: CUBEIDE:1.18.0
Firmware: STM32Cube_FW_H7_V1.12.1
Board: NUCLEO-H745ZI-Q
The problem is as follows: when using this chip for dual core communication, reproducing according to the example given by ST, communication cannot be carried out no matter what.
Through debugging, it was found that the problem lies in the OPENAMP_create_endpoint() function in the M4 core. The return value is -2005, but as a beginner, I am unable to pinpoint where the problem lies. I will attach my project at the end of the article.
My original goal was for the M7 core to send data to the M4 core, which would then print the data while the M7 core's LED would flash.
I have reviewed the corresponding routines in ST's AN5617 and firmware, and watched the corresponding videos, but still cannot solve the problem. I request your help
- Labels:
STM32H7 series
2025-04-21 2:08 AM - edited 2025-04-21 2:13 AM
Hello @MECHO ,
In fact the issue has been already reported in this post.
In fact in your non-working project, you have this warning:
<command-line>: warning: "RPMSG_BUFFER_SIZE" redefined
<command-line>: note: this is the location of the previous definition
So in conclusion:
You have two issues from the beginning:
- You didn't update the linker files to allocate memory for OpenAMP.
- An issue with the generated code with STM32CuebIDE 1.18.0 (a regression from older versions)
2025-04-16 7:47 AM
Hello @MECHO and welcome to the community,
OpenAMP needs a shared memory between both cores and accessible by both cores.
You need to declare a memory section where the message will be stored.
Looking at your project there is no declaration of that shared memory for OpenAMP in the linker file and the openamp conf file.
Look for example at the linker files in the example: Projects\STM32H747I-EVAL\Applications\OpenAMP\OpenAMP_PingPong\
CM4:
MEMORY
FLASH (rx) : ORIGIN = 0x08100000, LENGTH = 1024K
RAM (xrw) : ORIGIN = 0x10000000, LENGTH = 288K
OPENAMP_RSC_TAB (xrw) : ORIGIN = 0x38000000, LENGTH = 1K
OPEN_AMP_SHMEM (xrw) : ORIGIN = 0x38000400, LENGTH = 63K
__OPENAMP_region_start__ = ORIGIN(OPEN_AMP_SHMEM);
__OPENAMP_region_end__ = ORIGIN(OPEN_AMP_SHMEM) + LENGTH(OPEN_AMP_SHMEM);
CM7:
MEMORY
FLASH (rx) : ORIGIN = 0x08000000, LENGTH = 1024K
RAM (xrw) : ORIGIN = 0x20000000, LENGTH = 128K
ITCMRAM (xrw) : ORIGIN = 0x00000000, LENGTH = 64K
This memory sections are used by the Common\Inc\openamp_conf.h:
#else
* for GCC add the following content to the .ld file:
* MEMORY
* OPEN_AMP_SHMEM (xrw) : ORIGIN = 0x38000400, LENGTH = 63K
* __OPENAMP_region_start__ = ORIGIN(OPEN_AMP_SHMEM);
* __OPENAMP_region_end__ = ORIGIN(OPEN_AMP_SHMEM) + LENGTH(OPEN_AMP_SHMEM);
* using the LENGTH(OPEN_AMP_SHMEM) to set the SHM_SIZE lead to a crash thus we
* use the start and end address.
extern int __OPENAMP_region_start__[]; /* defined by linker script */
extern int __OPENAMP_region_end__[]; /* defined by linker script */
#define SHM_START_ADDRESS ((metal_phys_addr_t)__OPENAMP_region_start__)
#define SHM_SIZE (size_t)((void *)__OPENAMP_region_end__ - (void *) __OPENAMP_region_start__)
#endif
As you didn't declare this shared memory it seems that OpenAMP library can't find a memory where to store the shared messages.
Hope that helps.
2025-04-16 8:15 AM
Thank you for your reply. May I ask how to declare this shared memory? I compared the contents of my files and did not see any abnormal situations.
If you feel that my operation is incorrect, please help me modify it in my project so that I can clearly see what I did wrong. I once again request your assistance.
2025-04-16 8:24 AM - edited 2025-04-16 8:27 AM
Please review the linker files OpenAMP_ttest\CM7\STM32H745ZITX_RAM.ld and OpenAMP_ttest\CM4\STM32H745ZITX_RAM.ld
This is what you have in your linker files:
For CM7:
MEMORY
RAM_D1 (xrw) : ORIGIN = 0x24000000, LENGTH = 512K
FLASH (rx) : ORIGIN = 0x08000000, LENGTH = 1024K /* Memory is divided. Actual start is 0x8000000 and actual length is 2048K */
DTCMRAM (xrw) : ORIGIN = 0x20000000, LENGTH = 128K
RAM_D2 (xrw) : ORIGIN = 0x30000000, LENGTH = 288K
RAM_D3 (xrw) : ORIGIN = 0x38000000, LENGTH = 64K
For CM4:
MEMORY
RAM_EXEC (rx) : ORIGIN = 0x10000000, LENGTH = 128K
RAM (xrw) : ORIGIN = 0x10020000, LENGTH = 160K
And look at what I shared previously as linker files content.
You have this is missing:
And forget about the files location as they are not the source of the issue.
2025-04-16 8:50 AM
Thank you for your answer, but there is still a problem on my end, even though I have made changes to the corresponding code according to your suggestion.
However, the debugging situation is still the same as before, with a return value of -2005, which makes me very confused. If you feel there are still issues, please make the necessary modifications directly in my project. Because I may make mistakes and receive many invalid responses, I believe direct modification is the most effective way. I earnestly request your assistance.
2025-04-16 8:59 AM
First, please use </> button to share you code. Please read this post.
Second, please remove this memory region declaration at 0x38000000:
as it's already used by:
2025-04-16 9:21 AM
这是我的 M4 和 M7 内核的主要功能、闪存和 RAM
M4(FLASH.ld)
/* Entry Point */
ENTRY(Reset_Handler)
/* Highest address of the user mode stack */
_estack = ORIGIN(RAM) + LENGTH(RAM); /* end of RAM */
/* Generate a link error if heap and stack don't fit into RAM */
_Min_Heap_Size = 0x1000; /* required amount of heap */
_Min_Stack_Size = 0x800; /* required amount of stack */
/* Specify the memory areas */
MEMORY
M4(RAM.ld)
/* Entry Point */
_Min_Heap_Size = 0x200; /* required amount of heap */
_Min_Stack_Size = 0x400; /* required amount of stack */
MEMORY
M7(FLASH.ld)
MEMORY
FLASH (rx) : ORIGIN = 0x08000000, LENGTH = 1024K /* Memory is divided. Actual start is 0x08000000 and actual length is 2048K */
M7(RAM.ld)
/* Entry Point */
_estack = ORIGIN(RAM_D1) + LENGTH(RAM_D1); /* end of "RAM_D1" Ram type memory */
/* Memories definition */
MEMORY
__OPENAMP_region_end__ = ORIGIN(OPEN_AMP_SHMEM) + LENGTH(OPEN_AMP_SHMEM);- Mark as New
2025-04-16 9:21 AM
Also please read this article: How to implement inter-processor communication in an STM32H7 using OpenAMP
2025-04-16 9:24 AM - last edited on 2025-04-16 9:32 AM by mƎALLEm
感谢您提供另一个答案,但我只是复制了他的代码并遇到了异常。
Translation:
"Thanks for providing another answer but I just copied his code and got the exception"
2025-04-16 9:31 AM - edited 2025-04-16 9:34 AM
Please kindly write in English.
And please follow step by step the article I provided. Don't just copy the code. You need also to follow the CubeMx configuration including the MPU configuration.
If you have an issue while following the steps described in that article you need to post your question in it.
