NUCLEO-H743ZI USB printf works in STM32CubeIDE but not in Keil
LKris.1
I have a problem with using the printf function in Keil. I used the STM32CubeMX to setup a project and generated the code for Keil.
All settings in CubeMX is standard, only thing changed is the USB_DEVICE set to Communication Device Class (Virtual Port Com).
If this is setup and genrate for STM32CubeIDE and then in main.c I add #include "stdio.h" and within User Code 4 I insert the following, then printf is working on the USB connection.
/* USER CODE BEGIN 4 */
int __io_putchar(int ch) {
uint8_t c[1];
c[0] = ch & 0x00FF;
HAL_UART_Transmit(&huart3, &*c, 1, 10);
return ch;
int _write(int file, char *ptr, int len) {
int DataIdx;
for (DataIdx = 0; DataIdx < len; DataIdx++) {
__io_putchar(*ptr++);
return len;
/* USER CODE END 4 */
If i then do the same thing for keil, its not working, anyone who can guide me how to solve this.
Peter BENSCH
Compilers use different implementations for printf, GNU GCC calls e.g. __io_putchar, others call fputc
You could try:
#ifdef __GNUC__
  #define PUTCHAR_PROTOTYPE int __io_putchar(uint8_t ch)
#else
  #define PUTCHAR_PROTOTYPE int fputc(uint8_t ch, FILE *f)
#endif // __GNUC__
// * @brief  Retargets the C library printf function to the USART.
// * @param  None
// * @retval None
PUTCHAR_PROTOTYPE
// Place your implementation of __io_putchar/fputc here, e.g.
  HAL_UART_Transmit(&huart2, &ch, 1, 3);
  return ch;
Good luck!
/Peter
3 REPLIES 3
Peter BENSCH
You could try:
#ifdef __GNUC__
#else
#endif // __GNUC__
// * @param  None
// * @retval None
PUTCHAR_PROTOTYPE
  return ch;
Good luck!
/Peter
Keil doesn't use syscalls/write​
Hi Peter
I just tried this, actually i also tried this earliere, but its still not printing anything on my serial monitor.
Do you have an idea why its not working with my NUCLEO-H743ZI and Keil?
