Not able to ping STM32F407ZT Ethernet connection.
TG.3
I have configured ethernet and LWIP using stm32cube ide. But ethernet connection is not established.
waclawek.jan
Try with cable connected while reset. That's how the example is written.
Other than that, debug as usually - check clocks both physically (i.e. that there is 25MHz/50MHz clock on the ETH clock input pins on STM32), check that PHY is working (observe MDIO/SMI-related registers in ETH, observe signals on MDIO/SMI pins), check content of PHY registers retrieved through MDIO/SMI, check STM32/ETH MII/RMII connections to PHY, check PHY connections to magnetics, check ETH setup in software.
What hardware is this?
TG.3
Thank you for your response i am using DP83848
