Not able to ping STM32F407ZT Ethernet connection.
‎2022-04-01 12:37 AM
I have configured ethernet and LWIP using stm32cube ide. But ethernet connection is not established.
Ethernet
STM32CubeMX
STM32F4 Series
‎2022-04-01 1:25 AM
Try with cable connected while reset. That's how the example is written.
Other than that, debug as usually - check clocks both physically (i.e. that there is 25MHz/50MHz clock on the ETH clock input pins on STM32), check that PHY is working (observe MDIO/SMI-related registers in ETH, observe signals on MDIO/SMI pins), check content of PHY registers retrieved through MDIO/SMI, check STM32/ETH MII/RMII connections to PHY, check PHY connections to magnetics, check ETH setup in software.
What hardware is this?
‎2022-04-01 1:36 AM
Thank you for your response i am using DP83848
