‎2022-09-14 02:01 AM
I used Cubemx to configured the system clock to 180MHz. Why is the system clock in the generated project code...... 6 zeros...... 16MHz? Can I change 16MHz to 180MHz?It simply changes the number after "SystemCoreClock" to 180000000?
‎2022-09-14 02:38 AM
MCU starts from an internal clock, when you get the external clocks and PLL running the value will be adjusted.​
