MDK-ARM project generation failed
Glen Cook_2
Using the latest version 5.5 of stm32cubemx. When I try and generate a new project I get the following error after clicking generate code
The resulting project file is unusable.
I've attached the ioc file for this project.
I'm presuming this is a bug that has to be fixed by the cube team, but if someone could come up with a workaround in the meantime ;)
Cheers
Glen.
6 REPLIES 6
Khouloud ZEMMELI
​Hello @Community member​ ,
issue  has been detected, it will be fixed in a next release.
Problem appears with java 13 version, could you please switch to an other java version (8 for expl)?
Thanks,
Khouloud.
Glen Cook_2
Hi Khouloud,
Thanks for the reply.
I do have java 8 installed, not java 13, and the problem is still there.
Anything I can do to get it working until the next release?
Cheers
Glen.
Khouloud ZEMMELI
Could you please share your .log file ?​
Glen Cook_2
Here you go....
Log file attached
Cheers
Glen.
​This will be internally checked, we are deeply sorry for any inconvenience this may have caused.
Best Regards,
Khouloud.
Gulev.Borislav
The folder names are simple. The problem remains.
Keil version 5.29.0.0
CubeMX 5.6.0
