Maximum baudrate error on CubeMX on USART2 STM32F030C8
Alef Rosa
Posted on June 22, 2018 at 22:03
Good afternoon!
My name is Alef, I'm trying to set up the usart2 baudRate from STM32F030C8 to 2Mbps but I can not succeed.
I'm using 48MHz clock so according to the manual, at 16 samples, I should be able to reach up to 3Mbps, but CubeMx says the limit is 500kbps. But if I go in code and manually put 2000000 it seems to work normally.
My questions are:
  • I wonder if this is a Bug from CubeMx?
  • If not, why this lower limit?
  • Using USART2 with 2Mbps briefly, could it generate any problems in the future?
Thank you all.
#cubemx-stm32f103c8t6 #baudrate
4 REPLIES 4
Imen.D
Posted on June 25, 2018 at 11:22
Hello
alefkta
Can you please confirm that you are using the latest STM32CubeMx version 4.0.
With Regards,
Imen
Imen
Posted on June 25, 2018 at 17:39
Hello
Almeida_Costa_Rosa.A
Thanks for your feedback.
This is an issuein CubeMX. In fact, as you said,
the maximum value of Baud Rate should be 3 MBits/s in case of 16 samples and 6 MBits/s in case of 8 samples.
It will be fixed next release.
Please do not hesitate to contact me for further details.
Thanks and regards,
Mohamed
Posted on June 25, 2018 at 17:18
Yes.
The version of STM32CubeMx is 4.26.0.
Thank you.
Alef Rosa
Posted on June 26, 2018 at 15:52
Thank you all.
