macOS CubeMX can't set project directory.additional it's icon doesn't display
Options
2016-08-10 6:43 AM
Posted on August 10, 2016 at 15:43
Java version 1.8u102.
I can't set project name in project settings, any name will get a alert ''Location cannot be found or created, Please change project location Name''when I use root run it, things seems fine, can you to fix this? #stm32 #!cubemx #cubemx
Labels:
- Labels:
STM32CubeMX
Options
2016-08-11 1:56 AM
Posted on August 11, 2016 at 10:56
Hi Tension,
Could you precise with which MX version you have found the issue. So, we can verify it.-Syrine-
