I used stm32f407VGT for Ethernet.
2019-04-24 10:45 PM
2019-04-24 10:48 PM
I missed the problem.
I used stm32f407VGT for ehternet.
I just set the MII with LWIP and Clock. But whenever I generate the code, STM32CUBEMX is stoppped on "Generating EWARM project.." process.
What is the problem and how do I fix it?
>> without LWIP, the code generate is succeed.
2019-04-24 11:01 PM
Below log is the file "./stm32cubemx/ STM32CubeMX"
I really wonder how do I fix it.
2019-04-25 14:55:56,913 [INFO] ProjectBuilder:1489 - Time for Copy HAL[0] : 456mS.
2019-04-25 14:55:52,479 [INFO] CodeEngine:190 - oldGeneratedFile, D:\AProject_2018\19)Lucis\code\Lucis_Ethernet\Inc\stm32f4xx_hal_conf.h_save
2019-04-25 14:55:52,911 [INFO] CodeEngine:208 - Generated code: D:\AProject_2018\19)Lucis\code\Lucis_Ethernet\Inc\stm32f4xx_hal_conf.h
2019-04-25 14:55:53,183 [WARN] IPConfigManager:2546 - IP not found : TIM
2019-04-25 14:55:53,184 [WARN] IPConfigManager:2546 - IP not found : gpio
2019-04-25 14:55:53,188 [WARN] CodeGenerator:2532 - IP not found : TIM
2019-04-25 14:55:53,189 [WARN] CodeGenerator:2532 - IP not found : gpio
2019-04-25 14:55:53,210 [INFO] CodeEngine:190 - oldGeneratedFile, D:\AProject_2018\19)Lucis\code\Lucis_Ethernet\Inc\main.h_save
2019-04-25 14:55:53,716 [INFO] CodeEngine:208 - Generated code: D:\AProject_2018\19)Lucis\code\Lucis_Ethernet\Inc\main.h
2019-04-25 14:55:53,755 [INFO] CodeEngine:190 - oldGeneratedFile, D:\AProject_2018\19)Lucis\code\Lucis_Ethernet\Src\main.c_save
2019-04-25 14:55:54,290 [INFO] CodeEngine:208 - Generated code: D:\AProject_2018\19)Lucis\code\Lucis_Ethernet\Src\main.c
