I am using STM32CubeMX (Version 6.0.1) to transfer a basic project using an STM32F407VGTX chip to Keil uVision5 (V5.32.0.0) but the project files are not transferring correctly. None of the files seems to be correctly assembled in Keil.
‎2020-10-28 1:55 PM
I have attached a screenshot of a comparison of a project that works (an old one that I created previously in an older version of STM32CubeMx) on the left hand side of the window versus one I just created today using the most recent version of STM32CubeMx (right hand side). Any idea why the project is not exporting to Keil correctly?
I have uninstalled STM32CubeMx and reinstalled. I have also installed the latest STM32Cube MCU Package for the STM32F4 Series (1.25.1) .
STM32CubeMX
STM32F4 Series
‎2020-11-02 8:03 AM
Hi PMorr.1,
As I can remark from the attached .log:
You have a specific "#" character in the path of your project folder, which may cause this problem.
Some special character in the generation path (e.g. "ä", "&", "#") prevent CubeMX from correctly generate the project when using MDK-ARM toolchain. Sorry for the inconvenience, this is a known issue and it has been reported internally for fix. Thanks for your patience.
Please try to change the generation path and check if the problem still occurs.
Reagards,
Khouloud.
‎2020-10-28 2:23 PM
‎2020-10-28 3:17 PM
‎2020-10-30 1:26 AM
Hi PMorr.1,
I can't reproduce the issue, the project is correctly generated from my side:
Could you please attach the STM32CubeMX.log to track the issue ?
Thanks,
Reagards,
Khouloud.
‎2020-11-01 1:38 PM
Hi Khouloud,
yes I eventually found the log file under the path:-
C:\Users\PMorrow\.stm32cubemx.
Please see attached.
I notice that the Inc and Src folders that are generated by STM32CubeMx for Keil are generated inside the following path:-
Project_Name\Core\Src
Project_Name\Core\Inc
In the previous version of STM32CubeMx the Inc and Src folders were not placed inside the Core folder
Project_Name\Src
Project_Name\Inc
I don't know if this is causing an issue but it seems strange that the folder paths have changed.
Hopefully, you find the problem within the Log file.
Thanks,
Paul
‎2020-11-02 8:03 AM
Hi PMorr.1,
Reagards,
Khouloud.
‎2020-11-03 2:58 AM
Thanks very much Khouloud.
Yes, I renamed the directory path to remove the # symbol and I had to delete the folders that were generated from STM32CubeMx and once I did that it was able to transfer the project correctly.
Thanks for your help,
Paul
