How can I get SAI internal synchronization of sub-blocks to work in CubeMX?
2019-10-13 4:50 PM
I'm trying to get 96kHz/24-bit I2S to work in full-duplex master mode. I select SAI 3A to be master, but "synchronous slave" is grayed out on SAI 3B. Is there something I'm missing in the settings to get it synchronize with sub-block A? I'm using a STM32H745ZI. The changelog says this problem was supposedly fixed in v5.2.0, so I'm not sure why I'm having this problem.
Bug-report
SAI
STM32CubeMX
STM32H7 Series
2019-10-14 2:44 AM
Hello @DSchr.80 ,
Thank you for your feedback, issue has been fixed in the 5.4.0 CubeMX version.
Best Regards,
Khouloud.
2019-10-14 2:44 AM
Hello @DSchr.80 ,
Best Regards,
Khouloud.
2019-10-14 12:46 PM
Is there a way I can update to 5.4.0 now? If not, when does ST expect to roll out this update?
2019-10-15 12:06 AM
5.4.0 version will be available to download this week.
Best Regards,
Khouloud
