Hi, I am using Stm32f207 Nucleo board and generated the initialization codes with cubemx. When I run the code with MX_LWIP_Init(); it's not getting executed. Commenting it works fine. Can anyone help me out to solve this issue...
SKast.1
2 REPLIES 2
Rim LANDOLSI
Hello @Community member​ ,
At first , let me thank you for reporting this issue.
I think you have to verify if LWIP stack is enabled in your *.ioc file pinout configuration .
I tried to reproduce the issue using stm32F207ZG Nucleo board and it works without any issue when enabling LWIP .
Thank you
Rim.
SKast.1
Hi Rim,
Thanks for the suggestion..
I have checked my .ioc file and LWIP is enabled.
Can you please share me the .ioc file configured.
