2024-08-19 08:17 AM
We've made a pack (using STM32PackCreator) that contains a few files with a proprietary file extension (.eis). When importing the pack in CubeMX these files are not included.
If I rename the files to .txt instead they are included when the pack is imported in CubeMX.
I can see that the files actually are in the pack by renaming it to .zip and unpacking it manually. Using STM32H7.
Does anyone know how to fix this? Is there a list somewhere with "approved" file extensions that can be modified?
Thank you
Anders
