failed set up clock 180mhz on STM32f427VI
Albatross
i put external clock 25Mhz and and via ppl clock couldnt get 180MHz
5 REPLIES 5
Piranha
Chief II
Power voltage scale and overdrive wrong... Datasheet section 6.3.1.
How I configure in cube or after generate the code?​
Finding those settings is faster than asking in a forum!
I don't understant where to configure in code or via cube
You are the developer! You must search for possibilities, decide which ones are best suited and implement them.
My advice is to drop CubeMX code generation and to learn real software development, or you'll never be able to make anything useful!
