Error downloading the following files: crdb.zip (Problem during download)
hesam moshiri
When the STM32CubeMX or STM32MCUFinder try to update the database, I receive this error at the final step. I tried many things but all failed. It happens recently. I had not such a problem before.
5 REPLIES 5
Khouloud ZEMMELI
Hello @hesam moshiri​ ,
Thanks for your post,
Are you using the latest CubeMX version?
Khouloud
Khouloud ZEMMELI
Also, could you please share your execution log file located at C:\Users\username\.stm32cubemx @hesam moshiri​ ? It will be helpful 🙂
Thanks, Khouloud
Hi Khouloud ZEMMELI,
I have an update, Yesterday night I just changed my IP to see what happens and it worked. So weird. if this is the local ISP or server problem, why this just happens for this file?!!
it seems this is the URL: http://xsel.stmcufinder.com/refresh/v2/crdb.zip
Possibly some AV software blocking?
I ran into this issue and it was caused by firewall protections that geoblocked domains from Switzerland (where that file seems to be hosted).
