2018-05-23 03:53 AM
Hello guy.
I' upgrade my CubeMX software to V.4.25.1 every thing is clear no problem. But when we try to generate MDK project CubeMX show an project generate problem ( see in attach pic.)
Please tellme how to fix it
Thank you
EDIT!!:: TrueStudio has the same problem.
#cubemx-4.25 #mdk-arm2018-05-28 04:19 AM
Hi@
Korsri.Prawit
Thanks for your feedback.
I'm not able to reproduce this problem, could you give me more details about the scenario to reproduce this issue(MCU, FW package version, MDK version).
Could you also send me the ioc?
regards,
Houda
2018-09-05 06:12 AM
Can you try generating the code while your .ioc file is closer to the root folder? Like in E:/Work/ in your case? I have had the same error when my project file was too deep in a nested folder structure. I am thinking that the '&'-symbol in your path could cause an issue.
Greets,
Jonas
2019-03-30 01:28 PM
if you save on your desktop this this trouble will solve. I had same trouble and I tried a lot of thing. right now I use but only this conditional.(save on your desktop). take easy..
2019-06-27 01:22 PM
My repository had some files (.cproject, .project, .settings) owned by root. After I changed the ownership to my own user, I could generate my files through CubeMX smoothly.
2019-08-15 12:15 AM
I have met this problem as you are today,Then I solve this problem by changing "Project Location�? of my Stm32cubeMX's Project to a folder which have pure English.
2020-01-20 01:46 AM
For Me the issue has been solved for me by returning back to MXCube 5.2 version
2020-02-01 02:31 PM
Dear CubeMX developers please resolve this issue !!!,
I have tried so many things like run as admin and put the folders in root with short names, nothing helps,
the project can be generated for any IDE but not the MDK-ARM.
I am on windows 10 with latest Java version updated.
2020-02-13 10:17 AM
I tried everything described above nothing helps. Now I write under several microcontrollers nrf52, TI, Silicon labs. Nowhere was there such a situation(there were other ha ha:) but at least described solutions) and here in General it is somehow bad. I got to the point where keil opens a project using this manual https://www.keil.com/pack/doc/STM32Cube/General/html/cubemx_proj.html
and imports settings from CubeMx but writes the following errors
STM32G071RBT6 - Nucleo board (noBSP)
LL tried
HAL tried
Keil version 5.29.0.0
CubeMX 5.5.0
2020-02-13 12:27 PM
looks like ST doesn't care about fixing this bug.
(I found workaround for this. I installed windows 7 on virtual box, and installed latest version of CubeMX and Java Runtime Environment in this virtual machine,
and generating projects inside virtual machine. This works for me).
