CubeMX code generation overwrites linker library options !!
Options
2022-01-25 2:42 AM
Hi, i'm running STM32CubeIDE 1.8.
I have a project with some libraries defined in the linker tab.
When i regenerate the code using CubeMX all the linker tab is wiped out to default values...
There is a way to overcome this?
Thanks!!
Labels:
- Labels:
STM32CubeIDE
STM32CubeMX
Options
2022-01-25 4:12 AM
I use with modified linker.ld scripts and i never had the issue youre describing.
What do you mean with "linker tab"
hit me up in https://www.linkedin.com/in/javiermu%C3%B1oz/
