CUBEMX and HAL COMMAND Question
‎2019-09-03 1:38 AM
Hi, I'd appreciate it if you could answer a few questions.
I try to use HAL_CAN_Recive_IT in the HAL example, but it's not automatically set up in CUBEMX. Why? And how do I use the HAL command in TRUESTUDIO?
STM32CubeMX
‎2019-09-23 8:49 AM
Processing functions (like HAL_CAN_Recive_IT) are not generated by STM32CubeMX: only initialization code is generated.
You have to refer to the examples provided in the relevant STM32Cube package of the device you selected.
-Amel
‎2019-09-23 8:49 AM
-Amel
