Stephane Bonnot
Visitor II
September 14, 2017
CubeMx 4.22.1 code generation issue in SystemClock_Config
  • September 14, 2017
  • 1 reply
  • 785 views
Posted on September 14, 2017 at 10:04
With STM32Cube_FW_L4_V1.9.0 when generating code using PLL (HSE or other), SystemClock_Config(void) is missing a diviser :
RCC_OscInitStruct.PLL.PLLM is not set and thus generates an issue ( default value is 0)
adding  RCC_OscInitStruct.PLL.PLLM = 1; // (or any value set in CubeMx)
solves the issue.
#4.22.1 #stm32-l4 #cubemx
Best answer by Imen.D
Posted on December 18, 2017 at 13:19
Hello
Bonnot.Stephane
Please use the last version of CubeMx 4.
This issue about 'PLLM is no more generated' is fixed in the CubeMx version 4.23 asmentioned in the Release note of STM32CubeMX
http://www.st.com/content/ccc/resource/technical/document/release_note/b2/02/4b/e3/81/32/49/c4/DM001076pdf/files/DM001076pdf/jcr:content/translations/en.DM001076pdf
Best Regards
Imen
1 reply
Imen.DBest answer
Hello
Bonnot.Stephane
Best Regards
Imen
