2017-01-11 11:34 PM
hi
I'm using CubeMX 4.18.0 recently.
by the way,
Every time An error occurs when creating a TrueStudio project using the CubeMX 4.18.0.
Please, help.
2017-01-29 09:23 AM
I sent you an email.Please check.
2017-01-29 09:46 AM
I can't help you with Cube issues.
Would suggest not building files off the Desktop.
2017-01-29 02:09 PM
Hi sohaeng.lee,
Thanks for putting your updates, this is helpful to support you.
I have reported internally your feedback about attach a project file.
I got your project file from your new created discussion. I will check your issue and come back to you.
Imen
2017-02-17 02:18 AM
This issue is already resolved based on this discussion
https://community.st.com/0D50X00009XkeisSAB
Imen
