could not verify st device
‎2022-08-29 10:51 PM
i cant uplode code in my stm32 Bluepill. error notification (could not verify ST device).
how to solve this problem
I also change change stm32fx.cfg file .but I face same problem .
STM32CubeMX
‎2022-08-29 11:25 PM
Welcome, @SAHME.1​, to the community!
The topic has already been discussed here several times (e.g. here:( the Bluepill have not contained original components for a long time, but counterfeits that behave quite differently. Therefore, the message "Could not verify ST device" may well be correct.
/Peter
/Peter
‎2022-08-29 11:46 PM
Thank you for your comment brother , is there any way to code bluepill use st-link on cube ide
‎2022-08-30 12:12 AM
ST provides tools (STM32CubeMX, STM32CubeIDE, etc) for their products free of charge.
Can you give a reason why ST should also support components from other manufacturers or counterfeits with these tools?
/Peter
