configUSE_TASK_NOTIFICATIONS
Gert_Lauritsen
you have to put "#define configUSE_TASK_NOTIFICATIONS 1" into FreeRTOSConfig.h to make notification to work.
Even cube has enabled the funktion. Cube removes the line every time its saves the project.
4 REPLIES 4
Sarra.S
Hello @Gert_Lauritsen
Try adding it to the "User Code Begin" or "User Code End" sections of the FreeRTOSConfig.h file, which are not modified by CubeMX
Bob S
Principal
I haven't tried this on an F7 with newer CubeMX, but in CubeMX 6.3, configUSE_TASK_NOTIFICATIONS is defined to 1 by default in FreeRTOS.h.  If you disable task notifications in CubeMX, it then adds
#define configUSE_TASK_NOTIFICATIONS 0
in FreeRTOSConfig.h.
Check your Middlewares\ThirdParty\FreeRTOS\Source\include\FreeRTOS.h and see if it has the default value there.
It's not because I have to set it in config file ( now that I know it). just that cube says it should have been set.
And normally a default value
Sarra.S
Hello @Gert_Lauritsen,
I've reproduced the issue and reported it internally (Internal ticket number 166614
Sorry for the inconvenience, I will keep you updated
