2022-01-19 10:27 PM
The PB7 pin is set as GPIO_EXTI7 and TIM17 is enabled for PWM output. In the generated code, the IRQ routine is generated wrongly as follow:
void EXTI9_5_IRQHandler(void)
/* USER CODE BEGIN EXTI9_5_IRQn 0 */
/* USER CODE END EXTI9_5_IRQn 0 */
HAL_GPIO_EXTI_IRQHandler(TIM17_BUZZER_Pin);
/* USER CODE BEGIN EXTI9_5_IRQn 1 */
/* USER CODE END EXTI9_5_IRQn 1 */
2022-01-20 01:03 AM
Hello @PX ,
Thanks for your feedback,
This is a known issue and already raised to the dev team. For more details, please check my answer in this thread CubeIDE incorrectly generates the initial code of EXTI handlers: namely, it substitutes the wrong names with User Labels
Sorry for any inconvenience that this may cause.
If you issue is solved, please close this post by clicking the "Select as Best" button. This will help other members of the community find this response more quickly
Sara.
2022-01-20 01:03 AM
Hello @PX ,
Sara.
2022-03-07 11:20 PM
