Assert error in STM32CubeL1: Need check definition of IS_TIM_MASTER_INSTANCE macro
Shilin
I get some bug. I use mcu stm32l152ve. Version 1.9.0. After update i got some errors.
When i init, timer 6, 7, i got assert error in
assert_param(IS_TIM_SYNCHRO_INSTANCE(htim->Instance));
because
#define IS_TIM_MASTER_INSTANCE(INSTANCE) (((INSTANCE) == TIM2)  || \
                                          ((INSTANCE) == TIM3)  || \
                                          ((INSTANCE) == TIM4)  || \
                                          ((INSTANCE) == TIM5)  || \
                                          ((INSTANCE) == TIM9))
#define IS_TIM_SYNCHRO_INSTANCE(INSTANCE)  IS_TIM_MASTER_INSTANCE(INSTANCE)
In previous versions was
                                          ((INSTANCE) == TIM6)  || \
                                          ((INSTANCE) == TIM7)  || \
it work perfect
Imen.D
Yes I confirm that TIM6 and TIM7 must be added to the IS_TIM_MASTER_INSTANCE macro.
I raised this internally for correction.
Thank your for highlighting this issue.
Best Regards,
Imen
Imen
4 REPLIES 4
Khouloud ZEMMELI
​Hello @Shilin​
Could you please share your ioc file?
Thanks,
Khouloud
Shilin
No problem.
Khouloud ZEMMELI
​Seems not a cubeMX Issue,
@Imen DAHMEN​  Could you please check it ?
Thanks,
Khouloud
Imen.D
Best Regards,
Imen
Imen
