2022-03-30 1:59 PM
"variablelist": [
"address":"0x200004a0",
"type":4,
"value": "{{payload}}"
"accesspoint":0
2022-03-31 2:37 AM
Hi @mmenn.15
You're right, write node help is not accurate enough
here are type number representing the variable type :
1- Unsigned 8-bit
2- Signed 8-bit
3- Unsigned 16-bit
4- Signed 16-bit
5- Unsigned 32-bit
6- Signed 32-bit
9- Float
10- Double
Thank for you're feedback, it'll be up to date on future release
2022-03-31 2:37 AM
Hi @mmenn.15
1- Unsigned 8-bit
2- Signed 8-bit
3- Unsigned 16-bit
4- Signed 16-bit
5- Unsigned 32-bit
6- Signed 32-bit
9- Float
10- Double
