2023-01-17 12:46 PM
Hello, I followed the tutorial with just one variable (extracted from an elf) there was no problem the variable showed in the chart. But when I added another variable to the code and got a new elf. I went to the variable node to add the new variable but there's none (the first variable also gone). I tried with other elf files from other projects but it doesn't work either. Thank you in advance! (I'm using the CubeMonitor in Window10)
2023-09-27 8:45 AM
Closing the ticket as no update since a while
2023-02-16 6:17 AM
Hello @NChan.7
Can you share your flow and elf file if possible.
2023-09-27 8:45 AM
