STM32CubeMonitor 1.10 on Windows does NOT start
  • March 25, 2025
  • 9 replies
  • 2997 views
Dear staffs,
I'm going to use "STM32CubeMonitor" for several Nucleo boards, such as Nucleo144 of STM32H563.
But, when I try to invoke, following dialog appears and does not proceed.
Why ?
Thank you
    Richard.Chvr
    Sounds strange, can you try on another port?
    Need to edit settings.js file (in <YourDrive>\Users\<xxxxxx>\.STMicroelectronics\stm32cubemonitor)
    change line :
    /** the tcp port that the Node-RED web server is listening on */
     uiPort: process.env.PORT || 1880,
    To give better visibility on the answered topics, please click on Accept as Solution on the reply which solved your issue or answered your question.
    kojimaAuthor
    Oh.. That's port for Node-RED...
    My "setting.js" file includes that port setting description line.
    Do you mean, change port number such as 1881 in stread of 1880 ?
    kojimaAuthor
    I tried several "188x"  but, same results...
    Richard.Chvr
    Ok , is this error happening at STM32CubeMonitor start or upon deploy ?
    Richard.Chvr
    When you change to "188x" , was the reported error on that 188x port or still on 1880
    kojimaAuthor
    New errors represents each changed port number, not still on 1880.
    Richard.Chvr
    Looks like an application is using the 188x ports
    Can you try on another rand 808x for exampl
    You can also check port availability thank to
    netstat -ano | find /i "<host_address:port_number>"
    kojimaAuthor
    Sorry for my delay response.
    I tried ”netstat -ano" command. But, no reported line related to port 1880 etc.. was seen in the response.
    I also tried on TCP port 8080 as you advised. But same result as bellow.
    There is no doubt that something is happening.
    But, that might not the what error report dialog says....
    Pavel A.
    April 3, 2025
    No doubt. Is any VPN or "security" software installed? especially Zoho/Manage Engine?
