Stm32 Cube monitor power having multiple bugs
MK..1
Hi
On windows:
1. STLINKv3PWR is not recognised by cube monitor power when connected a USB hub (select Board is empty).
2. some times the PC software takes up to 20 seconds to find the comport.
3. diconnection of the device (USB) duing acquisition leads to a hang of cube monitor. I couldnt even find a process to kill in task manager.
MK..1
Hi
What is the roadmap of cube monitor power?
Actually the software hangs quite often due to different reasons.
Can some one from ST comment on this? Possibly @Richard.Chvr ???
Br,
Klaus
Hi @MK..1
I'll check with development team and will come back to you.
I'm not an expert of power subject but you may however have look to this post
To give better visibility on the answered topics, please click on Accept as Solution on the reply which solved your issue or answered your question.
