stm cube monitor
Yifat dvir
Im trying to use a switch button to control a Boolean variable, but i couldn't find a way to make it work. If anyone know what i need to connect to it and to define i will be thankful.
1 REPLY 1
Richard.Chvr
Hello @Yifat dvir ,
You can find  the node help on the right side of the flow when selecting it (see below). Switch node is not a ST specific node and there's probably some more information in the node-red documentation.
To give better visibility on the answered topics, please click on Accept as Solution on the reply which solved your issue or answered your question.
