2023-08-19 10:44 PM
Im trying to use a switch button to control a Boolean variable, but i couldn't find a way to make it work. If anyone know what i need to connect to it and to define i will be thankful.
2023-08-31 07:23 AM
Hello @Yifat dvir ,
You can find the node help on the right side of the flow when selecting it (see below). Switch node is not a ST specific node and there's probably some more information in the node-red documentation.
