IOC configuration for digital signals to go low
Sushmita
Please find the given DSO image !!!! blue is fault signal and yellow is PWM
 I need to stop the PWM, if a fault will come, while doing this my PWM is  turning off  but not fully its showing a ramp down of 88usec and then becoming zero.
 given configuration in my IOC
GPIO setting for timer  and fault signal is
 GPIO mode: Alternating PUSH PULL
   pull down
1 REPLY 1
Richard.Chvr
Hello @Sushmita
I'm not sure to understand your problem, What STM32 Cube Monitor tool are you using?
To give better visibility on the answered topics, please click on Accept as Solution on the reply which solved your issue or answered your question.
