IOC configuration for digital signals to go low
Options
2024-03-06 3:01 AM
Please find the given DSO image !!!! blue is fault signal and yellow is PWM
I need to stop the PWM, if a fault will come, while doing this my PWM is turning off but not fully its showing a ramp down of 88usec and then becoming zero.
given configuration in my IOC
GPIO setting for timer and fault signal is
GPIO mode: Alternating PUSH PULL
pull down
1 REPLY 1
Options
2024-03-14 1:13 AM
Hello @Sushmita
I'm not sure to understand your problem, What STM32 Cube Monitor tool are you using?
