2024-01-05 06:02 AM
Hi Guys. I want to increase memory allocated to the eclipse, but I cant find the eclipse.ini fille.
Could you direct me into a right direction?
2024-01-05 06:04 AM
It is renamed to stm32cubeide.ini and can be found in the same directory as stm32cubeide.exe.
For me: "C:\ST\STM32CubeIDE_1.14.0\STM32CubeIDE\stm32cubeide.ini"
2024-01-05 06:04 AM
2024-01-05 06:21 AM
Yes, I have located it. I am using Linux and the heap limit (when indexing kernel was far too low
Thank you for your help.
