Where can i set the ROM adress like KEIL in stm32cubeide?
Raytheon
DEAR ALL:
Where can i set the ROM adress like KEIL in stm32cubeide?like follow picture!
5 REPLIES 5
Not using the tool. Look at the Linker Script
Raytheon
Sorry,what do you mean the  Linker Script,is Instructions?​
Cartu38 OpenDev
Lead II
*.ld file(s) is(are) linker script file(s). All memeory mappings are defined into
Linker scripts describe the memory placement and usage expectations. KEIL generates a Scatter File​ from the GUI settings. Try searching on the "linker script" term if unfamiliar
Raytheon
​Yse ,I find *.ld file(s),and if i can change the start ROM adress directly?
