When I build code in Release configuration, STM32CubeIDE doesn't show errors.
‎2023-05-24 1:55 PM
To test configuration Release, I intentionally made syntax errors in my code. When I switch build configuration from Debug to Release, STM32CubeIDE doesn't show errors on console. Then I tried cleaning project and building all, but nothing changed. I can see errors in build of configuration Debug.
In project properties -> C/C++Build, Configuration is set to Release [Active]. I would like to build my code in Release configuration.
What could be the reason ? “I would be very grateful if you could help me with this problem.
Thank you in advance.
STM32CubeIDE
‎2023-05-25 3:16 AM
Hello @TForest​
Could you provide screenshots of the Release build configuration.
KR,
Semer.
‎2023-05-25 3:55 AM - edited ‎2023-11-20 4:40 AM
Thank you for answering !
Here some screenshots of my configurations. Please let me know if you need more configuration screenshots. By the way I use C++ in my project. Also I noticed that when I build all in Release mode, I saw Build of configuration Debug on Console and it changed to Build of configuration Release on Console immediately. During Build of configuration Debug process errors appeared ,but as I said Build of configuration Release process started just after that.
‎2023-05-27 2:48 AM
@Semer CHERNI​ Is there something wrong with my configurations ?
‎2023-05-27 10:25 AM
Please post also the build log (from the terminal window/pane)
‎2023-05-27 12:23 PM
@Pavel A.​ Since it is too long, I had to save log into file. You can see log output for Release build.
‎2023-05-27 12:37 PM
In which source file have you made syntax error?
