AMoul
What's the correct procedure to add the X-CUBE-EEPROM package to SMT32CubeIDE?
  • May 5, 2020
  • 841 views
 I downloaded the en.x-cube-eeprom.zip package file and launched STM32CubeIDE's Embedded Software Package Manager tool but when loading "From Local..." the tool comes back with "Invalid zip file ot missing expected Pdsc file within pack root directory". I checked and the Pdsc file is indeed missing.
Thanks.
Herve PIERROT
Hello @AMoul​ ,
Every X-Cube can't be lodaded into STM32CubeMX or STM32CubeIDE. This possibility has been introduce recently and only newer packages are comaptible,
but lot of more are coming...
You can check the compatibility in this page looking at the column "STM32CubeMX Compatible"
https://www.st.com/en/embedded-software/stm32cube-expansion-packages.html#products
You can also download directly those packages from STM32CubeMX or STM32CubeIDE menus.
MGrub.3
This will not answer your question but I downloaded X-CUBE-EEPROM package and added needed files to my project. It worked well.
