UART is not working
demir
Senior II
I have checked connections and assured that everything is set up correctly. When I run the below code, I cant see anything on serial console.
Does anyone have any idea about the root cause ?
/* USER CODE BEGIN Header */
  * @file           : main.c
  * @brief          : Main program body
  * @attention
  * Copyright (c) 2024 STMicroelectronics.
  * All rights reserved.
/* USER CODE END Header */
#include "main.h"
#include <string.h>
#include <stdio.h>
/* USER CODE END Includes */
/* USER CODE BEGIN PTD */
/* USER CODE END PTD */
/* USER CODE BEGIN PD */
/* USER CODE END PD */
/* USER CODE BEGIN PM */
/* USER CODE END PM */
RTC_HandleTypeDef hrtc;
UART_HandleTypeDef huart2;
/* USER CODE BEGIN PV */
RTC_TimeTypeDef RTC_TimeRead;
RTC_DateTypeDef RTC_DateRead;
/* USER CODE END PV */
static void MX_RTC_Init(void);
static void MX_USART2_UART_Init(void);
/* USER CODE BEGIN PFP */
char* getDayofWeek(uint8_t number);
char msg[200] ={0};
char msg2[200]={0};
/* USER CODE END PFP */
/* USER CODE BEGIN 0 */
/* USER CODE END 0 */
  * @brief  The application entry point.
  * @retval int
int main(void)
  /* USER CODE BEGIN 1 */
  /* USER CODE END 1 */
  HAL_Init();
  /* USER CODE BEGIN Init */
  /* USER CODE END Init */
  SystemClock_Config();
  /* USER CODE BEGIN SysInit */
  /* USER CODE END SysInit */
  MX_GPIO_Init();
  MX_RTC_Init();
  MX_USART2_UART_Init();
  /* USER CODE BEGIN 2 */
  char *msg4 = "message4\n\r";
  HAL_UART_Transmit(&huart2, (uint8_t*)msg4,strlen(msg4),1000);
  /* USER CODE END 2 */
  /* Infinite loop */
  /* USER CODE BEGIN WHILE */
  while (1)
    /* USER CODE END WHILE */
    /* USER CODE BEGIN 3 */
	  char *msg3 = "message3\n\r";
	  HAL_UART_Transmit(&huart2, (uint8_t*)msg3,strlen(msg3),1000);
		HAL_RTC_GetTime(&hrtc, &RTC_TimeRead, RTC_FORMAT_BIN);
		HAL_RTC_GetDate(&hrtc, &RTC_DateRead,RTC_FORMAT_BIN);
		sprintf(msg,"current time is: %02d:%02d:%02d\r\n",RTC_TimeRead.Hours,RTC_TimeRead.Minutes,RTC_TimeRead.Seconds);
		HAL_UART_Transmit(&huart2, (uint8_t*)msg,strlen(msg),1000);
		HAL_Delay(1000);
		sprintf(msg2,"current date is:%02d-%02d-%02d-%s\r\n",RTC_DateRead.Month,RTC_DateRead.Date, RTC_DateRead.Year,getDayofWeek(RTC_DateRead.WeekDay));
		HAL_UART_Transmit(&huart2, (uint8_t*)msg2,strlen(msg2),1000);
		HAL_Delay(1000);
  /* USER CODE END 3 */
  * @retval None
void SystemClock_Config(void)
  __HAL_RCC_PWR_CLK_ENABLE();
  __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI|RCC_OSCILLATORTYPE_LSE;
  RCC_OscInitStruct.LSEState = RCC_LSE_ON;
  RCC_OscInitStruct.PLL.PLLM = 8;
  RCC_OscInitStruct.PLL.PLLN = 50;
  RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV4;
  RCC_OscInitStruct.PLL.PLLQ = 7;
    Error_Handler();
  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV4;
  RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV2;
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_0) != HAL_OK)
    Error_Handler();
  * @brief RTC Initialization Function
  * @PAram None
  * @retval None
  /* USER CODE BEGIN RTC_Init 0 */
  /* USER CODE END RTC_Init 0 */
  RTC_TimeTypeDef sTime = {0};
  RTC_DateTypeDef sDate = {0};
  /* USER CODE BEGIN RTC_Init 1 */
  /* USER CODE END RTC_Init 1 */
  /** Initialize RTC Only
  hrtc.Instance = RTC;
  hrtc.Init.HourFormat = RTC_HOURFORMAT_12;
  hrtc.Init.AsynchPrediv = 127;
  hrtc.Init.SynchPrediv = 255;
  hrtc.Init.OutPut = RTC_OUTPUT_DISABLE;
  hrtc.Init.OutPutPolarity = RTC_OUTPUT_POLARITY_HIGH;
  hrtc.Init.OutPutType = RTC_OUTPUT_TYPE_OPENDRAIN;
  if (HAL_RTC_Init(&hrtc) != HAL_OK)
    Error_Handler();
  /* USER CODE BEGIN Check_RTC_BKUP */
  /* USER CODE END Check_RTC_BKUP */
  /** Initialize RTC and set the Time and Date
  sTime.Hours = 0x12;
  sTime.Minutes = 0x11;
  sTime.Seconds = 0x10;
  sTime.TimeFormat = RTC_HOURFORMAT12_PM;
  sTime.DayLightSaving = RTC_DAYLIGHTSAVING_NONE;
  sTime.StoreOperation = RTC_STOREOPERATION_RESET;
  if (HAL_RTC_SetTime(&hrtc, &sTime, RTC_FORMAT_BCD) != HAL_OK)
    Error_Handler();
  sDate.WeekDay = RTC_WEEKDAY_TUESDAY;
  sDate.Month = RTC_MONTH_JUNE;
  sDate.Date = 0x12;
  sDate.Year = 0x18;
  if (HAL_RTC_SetDate(&hrtc, &sDate, RTC_FORMAT_BCD) != HAL_OK)
    Error_Handler();
  /* USER CODE BEGIN RTC_Init 2 */
  /* USER CODE END RTC_Init 2 */
  * @brief USART2 Initialization Function
  * @PAram None
  * @retval None
  /* USER CODE BEGIN USART2_Init 0 */
  /* USER CODE END USART2_Init 0 */
  /* USER CODE BEGIN USART2_Init 1 */
  /* USER CODE END USART2_Init 1 */
  huart2.Instance = USART2;
  huart2.Init.BaudRate = 115200;
  huart2.Init.WordLength = UART_WORDLENGTH_8B;
  if (HAL_UART_Init(&huart2) != HAL_OK)
    Error_Handler();
  /* USER CODE BEGIN USART2_Init 2 */
  /* USER CODE END USART2_Init 2 */
  * @PAram None
  * @retval None
/* USER CODE BEGIN MX_GPIO_Init_1 */
/* USER CODE END MX_GPIO_Init_1 */
  /* GPIO Ports Clock Enable */
  __HAL_RCC_GPIOC_CLK_ENABLE();
  __HAL_RCC_GPIOA_CLK_ENABLE();
  /*Configure GPIO pin : PA0 */
  GPIO_InitStruct.Pin = GPIO_PIN_0;
  GPIO_InitStruct.Mode = GPIO_MODE_IT_RISING;
  /* EXTI interrupt init*/
  HAL_NVIC_SetPriority(EXTI0_IRQn, 0, 0);
  HAL_NVIC_EnableIRQ(EXTI0_IRQn);
/* USER CODE BEGIN MX_GPIO_Init_2 */
/* USER CODE END MX_GPIO_Init_2 */
/* USER CODE BEGIN 4 */
	char* weekday[] = {"monday","tuesday","wednesday","thursday","friday","saturday","sunday"};
	return weekday[number-1];
/* USER CODE END 4 */
  * @brief  This function is executed in case of error occurrence.
  * @retval None
void Error_Handler(void)
  __disable_irq();
  while (1)
#ifdef  USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *         where the assert_param error has occurred.
  * @PAram  file: pointer to the source file name
  * @PAram  line: assert_param error line source number
  * @retval None
  /* USER CODE BEGIN 6 */
  /* USER CODE END 6 */
#endif /* USE_FULL_ASSERT */
This is what I suggested him in my first comment in this thread.
@demir Could you please close this thread by selecting one of the comments that solved your UART problem? or give the solution here and close it after?
18 REPLIES 18
AScha.3
which board ?
custom/ which cpu ?
What you connect to ---> usb ?
Are you sure the code is running?
Can you toggle a GPIO/LED at the same time?
Configuring the right pins, code not shown, connectivity not diagrammed. Hard to diagnose with the imagination.
Can you look at the signals with a scope?
I have added  HAL_GPIO_TogglePin(GPIOD, GPIO_PIN_14) to check if code is actually running, you are right that it doesnt run at all.
  * @file           : main.c
  * @attention
#include "main.h"
#include <string.h>
#include <stdio.h>
char msg[200] ={0};
char msg2[200]={0};
  * @retval int
int main(void)
  HAL_Init();
  MX_GPIO_Init();
  MX_RTC_Init();
  /* Infinite loop */
  while (1)
	  HAL_GPIO_TogglePin(GPIOD, GPIO_PIN_14);
		HAL_Delay(1000);
		HAL_Delay(1000);
		 HAL_GPIO_TogglePin(GPIOD, GPIO_PIN_15);
  * @retval None
    Error_Handler();
    Error_Handler();
  * @PAram None
  * @retval None
    Error_Handler();
  sTime.Hours = 0x12;
    Error_Handler();
  sDate.Date = 0x12;
  sDate.Year = 0x18;
    Error_Handler();
  * @PAram None
  * @retval None
    Error_Handler();
  * @PAram None
  * @retval None
  __HAL_RCC_GPIOD_CLK_ENABLE();
  /*Configure GPIO pin Output Level */
  HAL_GPIO_WritePin(GPIOD, GPIO_PIN_12|GPIO_PIN_13|GPIO_PIN_14|GPIO_PIN_15, GPIO_PIN_RESET);
  /*Configure GPIO pins : PD12 PD13 PD14 PD15 */
  GPIO_InitStruct.Pin = GPIO_PIN_12|GPIO_PIN_13|GPIO_PIN_14|GPIO_PIN_15;
  HAL_GPIO_Init(GPIOD, &GPIO_InitStruct);
  * @retval None
  __disable_irq();
  while (1)
  * @retval None
You need to debug your application. Put breakpoints where you suspect an issue or step by step your application it could be stuck in the Error Handler!
Thanks for directing me in the right way. You re right, application is stuck at error handler while configuring system clock. Could you please check for me if I did wrong configuration for the clock ?
    Error_Handler();
    Error_Handler();
Tell us a little more about the board and chip you're using here. Lacking much in the way of context.
You can comment out the call to SystemClock_Config() and the chip will just keep running with the boot settings.
Andrew Neil
You still haven't told us:
  1. What chip you're using
  2. What board you're using:
    • Is it an ST board? Give the name
    • Is it a 3rd-party board? Give a link to specifications, schematics, etc
    • A custom design? Give schematics
  3. How you're connecting to the UART
  4. Do you have an oscilloscope to check for signs of life?
Sorry guys.
My board is STM32F407VG-DISC1.
I am encountering an issue now that is I cant connect to the board. Please see the error I get below.
I have updated the ST Link firmware and issue disappeared. I can test that UART is working, I have just written a simple code to check and I can see via serial console that UART is fine.
On the other hand, the original issue still persists.
