STM32CubeIDE Versions for Windows 7
What are the newest versions of STM32CubeIDE and STM32CubeProgrammer that still work under Windows 7?  I have searched high and low but could not find a simple list of versions and host system requirements.  Thank you.
5 REPLIES 5
STTwo-32
Hello @StunningTechnology and welcome to the ST Community .
I think this post could answer your question.
Best Regards.
STTwo-32
@STTwo-32That says version 1.10 for the STM32CubeIDE, but is that the latest?
Also, it does not mention STM32CubeProgrammer.
STOne-32
Dear @StunningTechnology ,
Microsoft ended support of  Windows 7 by 14th January 2020 :
End of support for Windows 10, Windows 8.1, and Windows 7 | Microsoft Windows
by default all STM32CubeProgrammer versions prior to that date are supported and I can confirm that version 2.5.0 is supporting Windows 7.
More details on versions are here :
https://www.st.com/resource/en/release_note/rn0109-stm32cubeprogrammer-release-v2170-stmicroelectronics.pdf
Hope it helps you, Then you can try newer versions if it work on your selected STM32 series and see.
Ciao
STOne-32.
@STOne-32Thank you; is there such a chart for STM32CubeIDE?  I was trying to avoid downloading, installing and trying each version of both tools.
STOne-32
