STM32CubeIDE memory browser display bug.
JJaco.8
Software:
Version: 1.10.1
Build: 12716_20220707_0928 (UTC)
When I use the Memory Browser and display 32 bits wide, and hover my mouse over the LSB, it shows as at address 0x2001FFE3
But, if I change the display to 8 bits wide, it clearly shows the LSB at 0x2001FFE1
Surely both should show 0x2001FFE1
Both are set to "Little-endian"
1 REPLY 1
KDJEM.1
Hi @JJaco.8​ and welcome to the Community :),
For my side it is not a bug it is the principle of little Endia format.
The difference between the Big-endian and the little endian is descripts in the below table.
0693W00000VOEjqQAH.pngThe difference between the 32 bits and 8 bits wide representation in the little-endian format is find in the below tables:
0693W00000VOEkAQAX.pngFor more explanation I advise you look at this link.
Thank you
Kaouthar
