STM32CubeIDE: __attribute__((__packed__)) does not work; Build a File - no console output
‎2022-08-16 3:15 AM
Two questions.
First one: __attribute__((__packed__)) does not work: for a structure
typedef __attribute__((__packed__)) struct a_s {
uint32_t M;
uint16_t V;
uint8_t Data[1];
} Type_A;
sizeof(Type_A) returns 8, not 7.
Second one: after STM32CubeIDE update to 1.10.1 when "Build a selected file" (*.c), the file seems to be processed, but NO build results more seen in the CDT Build Console.
Any ideas?
STM32CubeIDE
‎2022-08-17 1:08 AM
Does not work, either.
P.S. Sorry, must revide! Yes, placing the attribute AFTER "}" just before the type name works! sizeof() returns 7.
typedef struct a_s {
uint32_t M;
uint16_t V;
uint8_t Data[1];
} __attribute__((__packed__)) Type_A;
‎2022-08-16 9:44 AM
‎2022-08-16 11:19 AM
Maybe try the correct syntax...
An attribute specifier list may appear as part of a struct, union or enum specifier. It may go either immediately after the struct, union or enum keyword, or after the closing brace. The former syntax is preferred.
‎2022-08-17 12:35 AM
It (struct __attribute__((__packed__)) {... , - placing after struct) does not work either.
‎2022-08-17 1:08 AM
uint32_t M;
uint16_t V;
uint8_t Data[1];
‎2022-08-17 2:41 AM
The "__packed__" attribute name is probably some leftover from old compiler versions and probably is deprecated. The current attribute name is "packed".
‎2022-08-17 4:34 AM
Both ((packed)) work, when modified according to the thread linked by @Nikita91 above: the __attribute__(()) should be not before or after struct but after } just before the type name:
uint32_t M;
uint16_t V;
uint8_t Data[1];
} __attribute__((packed)) Type_A;
‎2022-08-17 1:45 PM
I checked both names of "packed" and both correct attribute positions on GCC v10.3 and all combinations worked.
‎2022-08-22 6:52 AM
Hello @ColdWeather​
For the first question:
I used the same syntax as you but the issue didn't reproduce; sizeof(TypeA) return 8.
uint32_t M;
uint16_t V;
uint8_t Data[1];
} Type_A;
For the second question:
Check if you are pinning the console view
Does the issue is reproduced with other project in a different workspace.
Kind regards,
Semer.
‎2022-08-23 8:22 AM
Yes, gcc understands both variants with underscores and without. This is not new. Haven't checked clang, but gcc is quite an industry standard...
To the OP's question: use static_assert to verify the actual size. (#include <assert.h>)
